LI-ghtcycle
tomjasz said:There are no budget priced battery packs built from bare cells, in the USA. It's ALL China. It depends on the supplier and the standards they set...
Sadly 36V batteries are become scarcer. Forcing many to build their own. And that's not cheap. All the bits and pieces add to the costs. In the long run it makes sense for someone with multiple bikes or needing a special config or shape.
Ok, so you want to compare apples to apples or are you saying that there is no difference between cheap fake copies of good Japanese (Panasonic) or Korean (Samsung) 18560 cells? :wink:
I'm not sure if you haven't seen the 36V section of batteries on Luna's site? They still have some:
http://lunacycle.com/36v/
Sure, most manufacturing for ANYTHING you buy is from China, I may have mis-spoke, but the point is, you cannot compare Ebay "cell of the week" fake Chinese cells with faulty a BMS to the real deal that Luna sells.
Hell, even my Cro Motor is manufactured in China, but that doesn't mean it isn't a quality product designed in Croatia, and with the results I get, I believe the 93% + efficiency!
How much assembly is done in China and how much is done in the USA, really doesn't matter much to me, it's the fact that the quality of the product is backed up by a company in the USA, and they have enough inventory right here to replace a bad pack.
They also show you how to diagnose problems or service your kit with videos.
And other than low budget systems or ultralight ones using Astro Motors (Tangent comes to mind), if you're using less than 48V, your loosing a lot of wattage to waste heat needing higher amps to do the same work with a typical E-Bike motor.
I have noticed a considerable jump in efficiency by going up to 72V (20s Li-Ion) from 66.6V (18s LiPo) on a cargo bike pulling a trailer (gross weight 444 lbs rider + bike + 150lbs cargo) and sure, I didn't build the E-Zilla bike to be an "ultra miler". :lol:
I built it to go to track days at Portland International Raceway (hopefully in the near future when I get a bit more budget to get a stronger controller & battery).
That said, I was still able to go on a pretty long trip up and down some very steep long hills on this battery (sans trailer, just me at 180 lbs + 114 lbs bike = 294 Gross) for about 18 miles averaging 9 Wh/Mile with ZERO pedaling, this is because the BB spindle is shot, and I need to have a custom 19 mm (3/4") one made before I can pedal again. I did this with as much coasting as possible, but I still had to climb back up a 2 mile long 5% average grade hill. This was a pretty slow trip too, probably averaging closer to 10 mph but you get the point.
