El_Steak
My friend's brother has a landscaping business and he uses a Sokkia laser Level. The battery for this thing died and a replacement is 100$
I inspected the battery and found out it is a simple 4.8V pack made with 4 NiCd D cells. I bought some replacement cells for 4$ a pop, opened the pack and replaced the original cells.
If I take a voltage reading from the discharge leads on the pack, I get a proper reading of 5.05 volts. However, when I plug in the charger the light doesn't come on and nothing happens (no charging). Once after 10 minutes, a red light came on the charger for a few minutes and the pack actually discharged to around 4.9V . The charger didn't come on after that.
The charger connector has 3 pins instead of 2. The middle pin gets connected to the pack to the negative lead, but it first goes through a an electronic thingy (see pic below). Any idea what could be wrong ?
