youreaspeedemon
Been a long time, looking to clean out some stuff in the garage. Not posting this as an ad or anything so please don't delete or flag or anything of the sort, I'm just trying to get some feedback from you all on approximate values of this stuff.
The following stuff is on Specialized Stump Jumper full suspension mountain bike with front hydraulic disc brake and wide Crazy Bob tires. Has a pizza disc front sprocket to keep up at 40mph in top gear. It also has heavy duty custom torque arms from getadirtbike.
Bear in mind that this stuff was sourced and put together 12 years ago, the controller was updated internally when I got the lithium battery about 8-9 years ago. It's been minimally cycled and kept stored mostly around 80-90 soc
1. Crystalyte Phoenix 5304 Cruiser
2. 36-72V 48A Start Immediate Digital Controller (IRFB4110 Mosfets) from ebikes.ca
3. 72v 24s4p lifepo4 cellman em3ev triangle pack with a123 cells
4. Gen 2 large screen Cycle Analyst from ebikes.ca
5. Crystalyte Twist Throttle
6. Dual ebikes.ca super bright direct plug headlights
7. Two 72v 6a? chargers sourced through cellmans business em3ev
I have some other stuff that I never upgraded to because life gets in the way
Infineon controller (pretty sure) bigger and better than what I have on the bike
24v soneil chargers think 4a and 8a and other bits Throttle and cruise not sure what else, cleaning the garage and finding things as I go
It's unfortunately likely all dated stuff now and I assume that there isn't much value but I'm curious.
Thanks for reading
Thanks for reading
