disndat
Hey guys so I just switched my rear motor to a 20" and got another 24v battery to run at 72 volts.I hooked everything up as normal and went for a little spin around my parking garage.Everything was fine until I stopped for car to pass by and then lightly hit the throttle and puff nothing-power to the controller is dead.So usually this means Ive blown a fuse on one of the batteries and I replace it and everything is fine-but Ive blown 2 fuses and when I replaced them they just blew right away.So I figure that the controller is blown so I take out the controller and open it up to look at it.Nothings burnt and no obvious sign of shorting.So I close back up and one by one I hook it up to each of my 24v batteries and the controller comes on and seems fine-the motor is not hooked up at this point.So then I hook up one battery and plug in the motor and hall sensor and pop-the controller goes dead.So then I hook up just the battery and the hall sensor and everthing comes on.So what do you guys think-is the controller blown or the motor connection fried?Also is there anyone in Toronto that has experience with this stuff or should I just send it back to justin in vancouver?
Thanks
Chris
Edit update-So I opened the controller again and its definitely fried-I found a chip off one of the fets rolling around inside the case and it stinks of electric burns.So my question now is this-Is the motor fried as well or should it be fine?
Thanks
Chris
