Can’t say because the swingarm is also rebuild.How much does the GTS1000 chassis weigh as pictured?
Sorry, I am not native speaker … good or bad news for me? It‘s the design of the mainframe and the front end which make my decision to use it. To be honest I don’t like the normal design but I saw the potential in it with some modifications. I drove the up to 290kg/ 639lbs before we started to reinstall all the stuff. We need 5 hours for it and you mane don’t know how many screws and edges were in this bike. I also now that the material of the frame is Die-cast aluminum, so not easy to weld via wig.That's quite the truck you got there.
It will get some color painting.The frames got that Batmobile look to it.
The motor will be in the rear wheel. It’s a QS 273 70 12kW car motor."Quite the truck" is a good thing. It's the part that rolls. Figuring out how to hang the motor and batteries is a whole other thing!
Excellent, 20 kWh or less !The battery will be placed under the mainframe.
