Doctorbass
Wheazel said:So at what point is it reasonable (as in what testing/use is required to be done) to say that these sells live up to the hype and are a long lasting bargain?
Try finding better... :wink:
nechaus said:At this Price they are a bargin.
I Have a friend with an off grid setup using A123's His expecting 10 years of use with the way he has set his system up.
I certainly think its possible
Doctorbass said:Wheazel said:So at what point is it reasonable (as in what testing/use is required to be done) to say that these sells live up to the hype and are a long lasting bargain?
Wheazel said:Doctorbass said:Wheazel said:So at what point is it reasonable (as in what testing/use is required to be done) to say that these sells live up to the hype and are a long lasting bargain?
That will probably not be possible at this time, and my question was not a trollattempt.
I am merely interested to know from you with extensive battery experience.
Is there a risk that cells can start to die suddenly even if treated right,
or is it more or less certain that all of them will last a long time after initial tensiontests and loadtests turn out well?
Doctorbass said:2P is enough and will be ok at 60mph too.
60mph is around 10kW so in 20s it's like 130A current so each cells will see 65A continuous wich is way below their stress point!
1p would do the job too.
Remember these can take 300A continuous!
Nice project! wich motor do you plan to use?
Doc
mistercrash said:Doc one thing I'm not thankfull for is you are giving me a reason to start thinking of spending money I don't have. :lol:
mistercrash said:Can a 24S2P battery made of A123 20Ah pouches be run safely for a long time without a BMS if the pack is balance charged every time?
Doctorbass said:mistercrash said:Can a 24S2P battery made of A123 20Ah pouches be run safely for a long time without a BMS if the pack is balance charged every time?
NO they do require BMS.
Unlike the konion, any lifepo4 will not last long time without balancing feature
Doc
Hi Doc,Doctorbass said:For long life use, every lithium cells have some preferences. They don’t like heat so keep them between 10 and 25 celsius to prolong their life. They don’t like being too much time at full SOC and being depleted so keep them in a range between 80-20% SOC.
Doc
If you balance charge the pack with dual hyperion's and monitor the parallel groups with something like Celllogs you can do it safely.mistercrash said:That's disappointing. I really thought that if I have 24S that's broken down to basically 4 6S that can be balance charged with two Hyperion 1420i chargers, and a LVC on the controller set to something like 65V, I could do it without a BMS.
Vibration won't be an issue with the tabs if the pack is properly built (cell bodies, tabs and wiring all vibrate together).dnmun said:they do seem like a great value but i think the test of time will be whether they swell and puff up and if the tabs end up being too fragile for the high vibrations they get exposed to on the vehicle.
cor said:Hi Doc,Doctorbass said:For long life use, every lithium cells have some preferences. They don’t like heat so keep them between 10 and 25 celsius to prolong their life. They don’t like being too much time at full SOC and being depleted so keep them in a range between 80-20% SOC.
Doc
Do you know the temp spec of these cells?
Storage and operational limits?
Of course, I like to keep them long, but 25 deg C is not a realistic upper temp in many areas.
battman said:This may tie in with Doctor Bass's comment about them not liking being at full SOC for much time - be wary charging these in cold temperatures!
I have a 3P24S pack of these in a motorcycle in Arizona.
I noticed a significant irreversible capacity loss (10%+) and increase in IR after fully charging these cells (3.6V) during cold spells (it was < 10 Celcius but not as low as 0C) over the past couple of winters. Cold weather like that is not so common in the low desert here, but might be a more frequent occurrence for other folks.
Note that the cells I have are the Cellman ones, not the more recently available 20AH A123.
Doc
999zip999 said:Should batteries sit a bit befor charghing for temp to even out or to rest s.o.c. ?
nechaus said:I am ordering 150 of these babies..
god they are so cheap. cheaper than headways 15 ah cells. and that's shipped!!!!!
What bms are you ppl using for 24s?
Doctorbass said:ANY lithium cells DONT like to be charged in cold temp So it's not a matter of brand new grade A cells or rejected cells... it's a matter of physical and electrochemical conditions with lithium cells
If yuo read correctly the A123 documentations you will see that the recomanded temp during charging process is near the ambiant temp.
I don't know how many charge cycles. I have drawn 5630AH from a 60A pack, which would be about 93 cycles if I fully depleted the pack between each charge, but I rarely even deplete the pack to 50% before charging.999zip999 said:battman how many charge cycles?"
battman said:Doctorbass said:ANY lithium cells DONT like to be charged in cold temp So it's not a matter of brand new grade A cells or rejected cells... it's a matter of physical and electrochemical conditions with lithium cells
Thanks, I understand the concept of reading documentation correctly. The only documentation available to me was the attached spec sheet which does not mention charging conditions. If you can post a link to the additional documentation you have that describes the recommended charging temperature then I promise I will read that correctly too.
Many battery users are unaware that consumer-grade lithium-ion batteries cannot be charged below 0°C (32°F). Although the pack appears to be charging normally, plating of metallic lithium can occur on the anode during a subfreezing charge. The plating is permanent and cannot be removed with cycling. Batteries with lithium plating are known to be more vulnerable to failure if exposed to vibration or other stressful conditions. Advanced chargers, such as those made by Cadex, prevent charging Li-ion below freezing.
Fast charging of most batteries is limited to a temperature of 5 to 45°C (41 to 113°F); for best results consider narrowing the temperature bandwidth to between 10°C and 30°C (50°F and 86°F). Nickel-based batteries are most forgiving in accepting charge at low temperatures, however, when charging below 5°C (41°F), the ability to recombine oxygen and hydrogen diminishes. If NiCd and NiMH are charged too rapidly, pressure builds up in the cell that will lead to venting. Not only do escaping gases deplete the electrolyte, the hydrogen released is highly flammable. The charge current of all nickel-based batteries should be reduced to 0.1C below freezing.
