999zip999
100 TW
Thank you Docbass and agniusm. There are hundreds of people who read and get good info without the neg. comments and question marks. Keep it up. But we do need questions. Thanks again.
bigmoose said:Doc, you have real cells. Wondering if you can confirm some measurements and give me two others?
Cell thickness 7.2mm
Cell width 161mm
Cell height, not counting tabs, 227mm
cell tabs 45mm wide x 26mm long
I need the tab spacing from the edge of the cell foil pack, and the spacing between the + and - tab.
Thanks DOC! ... sorry if I missed these tab spacing dimensions somewhere... I searched.
ohzee said:That's interesting I am in Ohio and mine are being delivered via UPS. Supposed to show up in 2 days.
Hello Bigmoose, Here is the cell measurement
bigmoose said:FWIW I was planning on placing 0.010 inch fishpaper between my cells or after I check the temperature capability, might use overhead projector transparency film.
Ypedal said:newspaper ?.....
I would think something more fire retardant and that can withstand high temps would be better! Perhaps Teflon sheets? It comes in 1/32" sheets.
I discharged them at low current, i wasn't using external load, and iCharger 206b can dissipate 20W of heat, so thats around 5-6ams. I think you have to cycle discharge >5 times to get proper reading. I done just one cycle to match cell capacity for two projects, lower ones for scooter and rest for cargo bike. I bought 6 more cells through ONS power, it was a group buy back here in Lithuania, and fellow tested few returning >19AH capacity.miro13car said:agniusm,
you did not mention how you, at what current you discharged?
