battman
1 W
Doctorbass said:[If yuo read correctly the A123 documentations you will see that the recomanded temp during charging process is near the ambiant temp.
Doctorbass said:All from Battery Univercity:
Fast charging of most batteries is limited to a temperature of 5 to 45°C (41 to 113°F); for best results consider narrowing the temperature bandwidth to between 10°C and 30°C (50°F and 86°F). Nickel-based batteries are most forgiving in accepting charge at low temperatures, however, when charging below 5°C (41°F), the ability to recombine oxygen and hydrogen diminishes. If NiCd and NiMH are charged too rapidly, pressure builds up in the cell that will lead to venting. Not only do escaping gases deplete the electrolyte, the hydrogen released is highly flammable. The charge current of all nickel-based batteries should be reduced to 0.1C below freezing.
Thanks. That is generic advice for lithium but you mentioned earlier the A123 documentation indicates a charging temperature "close to ambient". Is "close to ambient" 10°C? The A123 documentation you have that covers charging temperature - if you have it in electronic form could you post it here please? This could be useful information if A123 cells (and the 20AH in particular) have a narrower recommended range than Battery University recommendations.
