NeilP said:
I am thinking about buying one of these...and here in the UK we have all house 240v 13 amp + wiring. My workshop ring main circuit is good for 30 amps at 240volt, so i am good fro a 7kW charger if needed...not that I plan to go that high, probably a 4kW
What I want to know , is now a few people have been using these for a while, what is the verdict, and which voltage range unit would be best for me.
What I really mena by that is which one ..if they are different, has the best adjustable range?
I am planning my next build at the moment for the 5403, and was looking at going up to 35 series..so 145volt at 4.15.
I currently run my 5304 build at between 20 and 24 series. so 84 volt.
Will these units be adjustable to suit between 20 to 35 series??
I strongly recommand you to buy one that is like 25% more voltage than you plan on using. Ex if you want 24s lipo, than ask for a charger for a voltage for 30s
The reason is that i ordered one for 100.8V ( 24s lipo) and the max adjustable voltage i have is 105V. If i try to modify the resistor near the pot ( the one that set the max range), it dont want to go over 105V and make a strange szzzz sound indicating that it become instable( not good...).
They call them 2000W but generally, the voltage and current they offer is all product that give around 1500W.. just like mine that they wanted to set to 15A max instead of 20A... I dont care about 120V ac at 20A draw or 240V at 10A draw.. but they seem to not accept seting it for output power over 1500W.
I succeded to boose the current to up to 22A ( diring short time) at 100V... but i dont feel confident about keeping that seting continusly...
Also.. if you want to activate the output without the need of having the voltage of a battery detected, you can just connect a resistor across the relay N-O contact... 1000ohm work well and than the relay activate so you have voltage at the output.
About the max voltage they set for you i thing that the component of all teh version of that charger vary depending of the voltage you want. I think that for a given range of voltage or power, they select components according to that... in other words, i thing they have let say 4 version of charger . one that they cah adjust from 12 to 36V with the capacitor and other parts optimized for that range of voltage and current , another for 36 to 72.. adn another for 72 to 105... , another for 105 to 200... etc... due to the higher number of parallel parts for the high current version etc...
That might be the reason why mine can't go over 105V... maibe the PWM is reaching 100% at that value... so That's why i recommand you to select a voltage little higher than what you plan to use... so by that way you will be able to readjust it to your desired voltage.. and the current limit should not be too affected if you use 25% more..
Doc
