DrkAngel
1 GW
DrkAngel said:Will clean, disassemble and inspect motor today.
Will evaluate and decide on type of bearing.
Since I lubricate gearbox every 1000 miles or so, I might replace with non-sealed bearings, might last longer!
I have a good quality digital caliper so I will try to confirm 12mm x 28mm x 8mm bearing size.
MY1018z 24V 450w notor
Inner bearing (gear) - still good
608z
ID 8mm
OD 22mm
W 7mm
Outer bearing (gear) - bad, drilled and "punched" out to remove
6001zz
ID 12mm
OD 28mm
W 8mm
Brush end motor bearing
608rs
ID 8mm
OD 22mm
W 7mm
Motor shaft bearing (Gear end)
unknown
would not disassemble easily - did not wish to risk damage
Brushes
L = 14.1mm W= 5.8mm H=5.4mm The wire length is 31.5mm (side connect wire )
(< 1/4" left and proper MY1018 brushes are $7 + $20 shipping (from Australia) - so I will retire this motor to parts bin, waiting for a burn up or ... ?)
Used my cordless leaf blower to clean out brush "dust".
Nasty cloud caught me by surprise!
