shock
Sounds right in spec for lipo power. I did 23 miles yesterday, of city. Ended @ 44. Waited until now to fire up the charger. Looking forward to some trail rides.
Sorry, I meant do you think your fall is what might have damaged the key, and started the shearing...kfong said:Crash was all my fault, just didn't see the tree with the low light.
BMC motors use a 5mm x 5mm x 11mm key. You can buy a 25mm (1") piece of 5x5mm keystock from many power equipment service/repair stores for a buck or two - it's a fairly common item. File a rounded end, trim to length, then file other rounded end. Also, FWIW - the key is the bit of metal that fits into the slot or keyway.kfong said:I replaced the keyway with one I milled out.
biohazardman said:I have trouble with flats as well. The last three and the only I think I have had in a couple of years were caused by the tire sliding on the rim cuz of braking forces with over sized rotors and tearing the tube stem at it's base. If I keep after the tire slippage, by letting the air out and pulling things back into place making the valve stand straight up again regularly, I am golden else, I have flats even with 60LBs of pressure in the tire. Been thinking of a little contact cement on the rim tire interface. Probly won't take much. With your pressure set for trail riding things have to be far worse I wish you luck.
z50king said:Nice read and thank you for the pictures.
I bought 4 of the Blue 6S 5Ah packs two Black Fridays ago on super sale. I am still running them in my goped 6S4P and they are giving me about 11Ah overall from the 19Ah they gave me when I started using them.
kfong said:These were inexpensive packs, I'm hoping the added compression will help with the packs lifespan as well as any fires. My first packs from them lasted 3 seasons. Lipos also age with time so I felt they worked out well for the money.
