Been just riding this bike all summer. Finally given up on the tubeless tire route. It seemed unreliable for jumps, it could be due to the ghetto rim setup. Any large drops, would cause a separation and eventual rim leak. Gone back to tubes, and liners; but finding Kevlar tires to be an acceptable route to take.
Finally had a break down, the side plate of the BMC motor had worked itself loose. This gave the impression of bad worn out bearings. I had so much lateral movement, that I could rock the rear tires side to side a bit. Motor is currently off the bike. I had initially tried to just tighten the screws, but it didn't help. What I found was the bearing had also rocked itself out and caused the plate not to seat. I needed to remove the press fit bearing completely to clean out any possible dirt before pressing it back. The bearing seemed fine after inspection, bike should be up and running this weekend.
While looking at Ebikes.ca spoke calculator, I had noticed an Isis torque sensor. I originally turned down the Thun version since it was a tapered crank. This Isis bb had me thinking about getting rid of the throttle again, so I ordered one. I will post how it turns out in the days ahead, and the mods I plan to do to make it workable for trail riding.
