The beginning of the build. Some things later were changed and improved (controller, battery mount). Pics of the final bike are on page 6.
The first thing was to find a solid DH Frame with the option to mount custom made torque arms. I decided to go with Votec VR 150 DH Frame which is made of 7000AL and has very big upper swingarms (they should handle the torque well).
The Frame is from Germany and costs about 500-600€.
Front shock, brakes, pedals, steerer, headset everything is self chosen and built togehter. I spend a lot of time to find the right parts and fit them together well.
The last thing was the Motor and Rims. Wanted to wait for more infos on cystalyte the Crown TC 80/100 but not much experiences where coming so i decided to order Cromotor and im very hapy with it.
The wheels are double wall cross lacing 20" BMX rims with 2,5 / 16" Moped tires. Spokes are 13ga front and 12ga at the back -ordered from Holmes Hobbies. The back rim is custom drilled to make the steep spoke angle possible. (loooots of work!!!). Battery is mounted on the fork in peli 1300 case and its removeable (BIG THX to oanet for this great idea!).
more data:
- 22s9p Sony Konion VTC4, charge with 8A to 90V (4,1v per cell), No balancing needed (the data sheet calaims so)
- Lyen IRFB 4110 18 FET EB 318 controller currently set to 100A phase and 60A battery (its about 5kw)
- CA V3 with expansion
- AWI 5k Thumb throttle
- Cromotor in 16 equavalent bmx rim. bigger phase wires. thermistor added.
- LED 1A for low beam + 2A driven LED for high beam. both with wide angle lens.
- LED turn signals and taillight with brake light function (have to think of how to connect the brake light to my e-brake switch)
- real moped horn^^
- Rock Shoxx boxxer fork
- Shimano Saint brakes
speed: 75km/h hot of the charger on flat ground. for me very fast acceleration (its no wheele machine of its only 100A phase / 60A batt)
range: about 50km at 25-30 Wh/km with full speed tested and it should be about 150-200km on 33% controller speedlimit (20km/h).
weight: bike 34kg, battery 12kg = 46kg
very very heavy bike (but very light for a moped)
some pics (no peli 1300 battery case added)
more data:
- real moped horn^^
