speedmd
Hi Wishes
I posted this also on the build thread.
Looks like they used the wrong chain (Looks like 8mm chain) and boxed them selves into a taller ratio. You can just pedal faster.
You need to swap out the sprockets for some #25 sprockets or mount the jack shaft further away. Most can fit a 11 or 12/72 (6 times reduction) with the 25 chain (same or more than stock). I made some eccentric bearing cups for the jack on mine and could go still much larger than the 72. Lighteningrods has adjustable plates for the jack which will allow use of a larger sprocket if you want to stay with a longer pitch heavy chain, but you still most likely will need to swap it out for a 219 pitch setup or run a very large diameter gear. The 25 pitch (quater inch) is the most compact of the bunch. You may want to go to a 50 or 52 on the secondary side also if you want torque.
