Mathurin said:nlc did a similar test here, except the motor was held immobile.
This were his results for battery volts/amps & amps in the phase cables:
36V 20A 45A
48v 20A 52A
72V 20a 65A
What voltage were you running at, fechter?
safe said:This chart from Wikipedia does a good job of making the "Buck Converter" (PWM) more understandable. Apparently it's only when in "discontinuous" mode (pulses too slow to keep things backed up) that the "effect" takes place. One might say:
"Oh yes, I do like it when my Buck Converter goes discontinuous."
...but then people will think you are being pretentious. :wink:
Malcolm said:This page http://www.4qdtec.com/pwm-01.html on the 4qd website explains the basics well.
Heat index for PWM:
10% - 10 times
20% - 5 times
33% - 3 times
50% - 2 times
HEAT IS REAL
Toorbough ULL-Zeveigh said:The extra heat is imaginary because the current thru an inductor has a real component & an imaginary component.
fechter said:It doesn't get ugly until you go discontinuous. I think 4QD explains this somewhere. Therefore, the motor heating with a PWM controller is nearly the same as it would be for pure DC.
Matt Gruber said:...anyway i spend a lot of time at LOW, like 1-2 mph, and my mbike draws 1 to 2 amps 36v and nothing gets hot.
my little Unite motor that is only 750 Watts and in my taller gear I can literally burn up my motor if I get on too steep of a hill.
:wink:The Motor Kit comes with the following:
X-5 750W Single Speed Hub Motor
Matt Gruber said:U climb steep hills at 10%? LOL
IMPOSSIBLE w/750w at 10%.
on a "death spiral" steep hill
have u cut back throttle to keep it cool?
the driver feeds the motor.
bad skills= overheat
good driving= happy motor
it it climbs at 13mph but gets hot
try 9 or 10 mph or ~60% of level speed.
mine drops to 16a @ 9mph on overpass
