safe said:Heat = Current Squared Times the Duty Cycle.
No...It...Isn't
Only current that flows thru a resistance produces heat.
Current that passes thru an inductive reactance does not.
If you have a better core material, the loss is less, therefore heat is less at the same current level.
Think of a magnetic ballast in a flourescent lamp. There is some heating from core losses, but it's miniscule compared to if you replaced the coil with a resistor ballast. The lamp would work the same i.e. same 'impedance' to limit the current to the same level the lamp requires, but the resistor would give off a lot more heat
safe said:In the end I'm stuck with another set of questions:
Does torque significantly increase because of the PWM "effect" or are you simply able to achieve comparable torque with less motor effort? (less heat produced allows the motor to handle the load better)
And the followup on this is that if REAL torque gains are to be found (not just ways to avoid overheating) then why would a controller be set up to even allow full throttle (peak current behavior) at low rpms?
Why even allow the "less desireable" condition to exist?
Couldn't a controller be made "smart" so that it exploited the PWM "effect" (discontinuous operation) so the user never even knew that the optimal behavior was being performed?
What if a "Cave Man" wanted to ride an electric bike? How might he "adapt" to the PWM "effect"?
For the same reason above I believe anyway. I've been very impressed with my 20 amp cyrstalyte controller because it produces good speed and range. The controller and motor never feel to get hot even on steep hills. Sure it's slow on steep hills, but I just use some pedal effort and I'm still moving along very fast. I know that when I swap in the 40 amp controller it climbs hills faster at the expense of more power, but the top speed doesn't change much (30 mph vs. 35 mph)
fechter said:Aww jeez.... you're making my head hurt again.
fechter said:If you back off part way with the throttle, you won't notice any difference until you back off far enough for the duty cycle to be less than what the limiter is making it do.
I know I'm "pushing peoples minds" again and asking the really hard questions but I think I'm getting close to really understanding the fine points of the PWM "effect".
Oh, and Einstein: 'boundry' is spelled 'boundary'. That's about all the help I can be at this point :wink:the "true" boundry is not between 100% duty cycle and a low percentage duty cycle, but the boundry between "continuous" current and "discontinuous" current.
Can you say without a shadow of a doubt when your bike is actually crossing the boundAry between continuous and discontinuos operation?
fechter said:Yes, I suppose you could design a circuit that would tell you when you went discontinuous, but as you point out, this occurs at a current below the normal operating area. In practice I think this would only happen going downhill or with a major tailwind.
The more I know the less I seem to know...
xyster said:As I study any subject in increasing depth, my learning efficiency (info per time) declines until the point where I give up
