MAGICPIE3FOCUSPOWER
Nice to see your bike is running! 8)
You are carrying battery in a backpack?
Thanks. Yes I am carrying my batteries in my backpack. I don't believe in the "duct tape ride", I want start a new trend for the first ride as a back pack ride instead.MAGICPIE3FOCUSPOWER said:Nice to see your bike is running! 8)
zombiess said:I would not go any higher on the phase amp setting, I lost another FET on my B phase again. I was set for 140A phase which I suspect is actually much higher since the software can only program the controllers as 18 FET versions.
Thanks, let me know when your start a build thread if you make one.samoloh said:nice build, I might do a similar build for my second ebike this summer
Scott said:At 125 (30s) volts when my batteries were about 70% discharged at 112 volts I pinned the throttle at 40mph my bike and it wheelied violently. I never tried pinning the throttle at lower speeds because I was running out of battery power to get home.
zombiess said:Welcome to the holy crap it's dangerous and really fun club.
I don’t have tools to make a metal box, or I did not over the summer when I was building it. I already have $80-$100 into this box and I am just about finished. Plastic was the only thing I could do myself easily so that’s the reason I went for it.dan974 said:If I were you I would forget polycarbonate, and go to Al...cause when it breaks it like glass, cuting surface...my side battery boxes covers broke rapidly , @least ad a sticker film on one or both side, it wil keep the pieces when it will crack :wink: ...my own experience...I had that material beetween my b...
Obiwan007 said:Scott, you gotta get a decent power supply man. I finally got two of ice cubes dell supplies so I can charge at 30 amps and it's awsome. Not that expensive. So what's the story on slip charge mode? Does it hit hard at just one power level, like standard regen braking or is it variable in some way? Can any Infineon controller do it. I never payed attention to it until you mentioned it just now. Timely since I spent today tuning up the magnet distance on my home built e-brake levers to get the regen braking to hit just right. So the throttle works the same on take-off but engages regen when you back off? Do you have to come to a complete stop for it to disengage? Obiwan
