Thanks, I’ll try that. The spoke under where the dent is at is pretty loose so I will need to tighten it up too. Since my batteries are still in my backpack I was sitting down so my battery wire would not come unplugged, that may have caused the problem also with all that weight being all on the rear wheel. MC rim/tire setup sounds pretty good. I am just worried about getting the tire clearance right.zombiess said:You could do what I would do, put some rubber around that spot on the rim, grab some channel locks and massage it back into place. Depending on the final result I'd leave it alone or replace the rim.
I've slammed the front/rear end of my bike into curbs on purpose at 20mph with an MC rim/tire setup, no issues and it was pretty smooth but doing it was a bit scary and I had to build up to the speed on several attempts.
Your welcome, yes the only thing I did was let go of the throttle to activate regen. Unfortunately I still need to take my wheel off to replace the tube. Also I never put a rear freewheel on and it would be good for the bike to be able to be pedal powered for the presentation.Obiwan007 said:Thanks for the video Scott. So that was solely regen via slip charge mode In the video simply from shutting down the throttle? I think zombiess suggestion is the path for you, at least for your presentation. He'll you may not even need to take the shell off the bike to get it to work. Obiwan
I’m glad I was able to get some video of regen before I messed up my rim. It happened literally 5 minutes later haha
