chridder said:
Hi ebikers,
Just wanted to let you know I had a few beers for courage and took the plunge into the ebike community.
I've hedged my bets and ordered the motor and controller from elifebike and the battery from BMSBattery.
Based on the pages of info I've read on this forum I went with the following:
--- 36V/ 48V 350W 9 Mosfets E-Bike Motor Controller with LED meter
- Voltage: 48V
- LED meter: with LED-810
- Controller Case : with E-Controller-B-black
- PAS: with PAS
- Throttle : with Throttle
--- 350W M100 Front E-Bike kit
- Voltage-Motor Color: 36V-Silver-(Hall Sensor)(261RPM)
- Wheel size:26inch
- Brake Lever: add Wuxing Brake
--- New design bottle ebike battery pack 48V10Ah Specification:
1. Normal voltage: 48V.
2. Continuous discharge current: 20A
3. Charge current: 3A.
4. 4P13S Li-ion 2.5Ah 18650 cells.
"yeah, so why are you telling us?" I hear you ask! ...
Well, because I'm mixing and matching a little bit I'm happy for you guys to point out anything I might need or need to do in preparation for assembly?
As you can see I'm going overvoltage on the motor for a bit more speed (they're relatively cheap if I fry it) but the controller max is 17A which I'm led to believe may keep the motor fairly happy.
I'm more than happy to provide pedal assist for most of my riding and will probably be using it in PAS mode most of the time.
So, any advice?
Will I need to do any soldering to hook it all up? (I'm fairly handy on the soldering iron).
Should I be careful going full power up hills or anything with this set up?
As background, my commute is about 25 km per day on reasonably flat ground with the occasional 10% hill. My calcs show I should easily achieve that with pedal assist.
That's enough babbling for tonight.
C ya.
Ps - it's a bugger the Aussie dollar is weak at the moment cause it cost more than I would've liked but fuel savings will hopefully make up for it.
It sounds like you may have read some of my posts.
I think that you will like the finished product. In fact, if I were not so invested in Lipo, your order list is exactly what I would order for a new build.
I have used/or have on order, all the items you have listed.
I ordered everything from BMS Battery(except controller) because I wanted the motor in black, but your motor kit is the "higher powered" Cute, which Elifebike tags as a "F" and BMS B. gives a suffix of "H".
I am not sure why D8veh as experienced over-heating with Q100 motors. Sunder, Fellow, Crossbreak, Mtl34 and I have used various Cute motors at Voltages up to 14S(58V?) and Amps in the 20's and none of us have had the Cute even get particularly warm.
But most of us have had over-heating with the tiny 6-FET controllers, especially if they are in a bag.
That is one of the reasons I like the 9-FET from ELB. It is larger and has lot's of air-space inside the case.
I am using one now on a "328" Cute(in a 24" whl.), and it is inside a bag, and although it gets warm, it is holding up fine.
It is a very smooth and quiet unit and I think even the 500W(19A) version would be safe on most Q100 applications(I have one here to try). BTW, they are available on Ebay, if you ever need to order one.
The cruise engages very quickly, almost too quick, after just a couple of seconds of holding the button down. I have not used the PAS with that controller, so I am curious as to what your experience will be with it. Speaking of PAS, did you order the "new style" crank sensor?
https://bmsbattery.com/ebike-kit/705-dual-hall-sensor-12-signals-easy-assembling-pas-ebike-kit.html
I think this is the one to use, as I have found the older style to be finicky to get to work.
I don't think you will need to solder anything(depends on Battery connector). I have replaced all of the kit connectors in the past when I wanted to shorten the cables/wires. You will have lot's of extra lenght w/ the frt. whl. kit and if you can, try and put the extra "loops" in a bag for a clean install. The one set of connectors I would recommend replacing or eliminating are the crimp-on bullets on the three phase wires. I use 3.5 mm bullets from Hobbyking, but one can just solder the wires directly. Make sure all the little pins are pushed in all the way in with the Hall, nylon connector.
As for hills, just make sure that you don't let the speed get too low, under, maybe, 10 mph. If you can get a good run up, it would take pretty long hill to get you slowed down that much, so you should be fine.
As for range, I usually get 1 1/2 miles per battery Ah, so your daily commute should not be a problem.
Let us know how it turns out.
EDIT: I see you have ordered the controller case. I have tried those(although, not with that controller)and have never been happy with the way they go together. If you feel like you might want to try something else, a good solution are sm. inexspensive "over the rail" frame bags, like these(half way down;
http://endless-sphere.com/forums/viewtopic.php?f=3&t=63940&p=1003770&hilit=scott#p1003770
There is room in the side pocket to stash extra wire. Mine is counterbalanced with a Lipo batt. You could put in a tool kit or whatever.
