motomech said:........, but your motor kit is the "higher powered" Cute, which Elifebike tags as a "F" and BMS B. gives a suffix of "H".
Doesn't the F mean front motor?
motomech said:I am not sure why D8veh as experienced over-heating with Q100 motors. Sunder, Fellow, Crossbreak, Mtl34 and I have used various Cute motors at Voltages up to 14S(58V?) and Amps in the 20's and none of us have had the Cute even get particularly warm.
But most of us have had over-heating with the tiny 6-FET controllers, especially if they are in a bag.
That is one of the reasons I like the 9-FET from ELB. It is larger and has lot's of air-space inside the case.
I am using one now on a "328" Cute(in a 24" whl.), and it is inside a bag, and although it gets warm, it is holding up fine.
It is a very smooth and quiet unit and I think even the 500W(19A) version would be safe on most Q100 applications(I have one here to try). BTW, they are available on Ebay, if you ever need to order one.
Yeah, but the MXUS/Outrider are at least 20 % bigger and I run about 20 % more current with the MXUS over the standard Cute(ELB 9-FET 17A vs. an Infinon 22A).neptronix said:Cool.
Get torque arms asap for that front motor though!
You can't really go wrong with this motor it seems. The efficiency for this little geared hub is quite good compared to other models, and probably competes with the more expensive ebikes.ca outrider to be honest.
Kwel beans.chridder said:Hello ebikers,
It's update time! the full kit has finally arrived and, as it turns out, elifebike beat bms battery by about 3 days bit all up I was pretty happy with about 7 to 10 days from order to arrival in Western Australia.
For those who didn't see my original post the kit is a q100h in front 26 inch wheel with 48v frame style battery rated at 20A continuous. Controller limited to 17A.
Last night I quickly plugged it all in and did a very dodgy masking tape job to hold it together (was too excited to make it neat) and went for a quick blast around the suburbs. OMG I am in love with my bike again! The motor looks so tiny in the wheel i wasn't holding much hope of it having much pulling power at all but this thing really does go well it will accelerate on the flat by itself to top speed no problems at all . Into a wind I put in a little bit of pedalling myself and maintain speed easily, same with small hills. On steep hills the speed drops off naturally but still really easy to pedal with it.
I did test it up about a 10% by itself and it will pull up but starts to bog down and get noisy and that's where I stop pushing my luck because I haven't got the torque arms on yet and I don't want a disaster in the first few days!
When it's flat or I'm pedaling I'm astounded on how quiet it is, I blasted past a lycra boy last night and I don't reckon he knew what hit him. Must've thought "geez that bloke's fit!"... such a great feeling
For my first ebike I reckon I've struck it pretty lucky with the combination I went for. I might be biased given it is my first ebike but I must say it is awesome. Thank you one and all for your great advice.
If you have any questions let me know as I did learn a few things along the way, like putting the wheel in backwards was a bad idea!
The older standard Cutes(250W?), both the frt. and CST rear. These are 328's in 24" wheels.neptronix said:Are you referring to your Q100C or did you test a Q100H?
Q100H is a significantly different motor than the older Q100 motors.
neptronix said:Looks like they've removed a lot of useful information when they updated their website, IE the note about double internal reduction.
Will I need to worry about torque arms?
260 would be better, as a 201 on 36V is kind of slow, 18 to 19 mph.Q100H 201rpm v 260rpm?
I seem to recall an issue when using the intergrated controller with the Cute. Dave(D8veh) will chime in on this. You can search this as well.....but there is a 20A Sine Wave Controller option for 09-Case. Thoughts?
It's a matter of features.What is the difference between the S-LCD3 and the S-LCD1 E-Bike LCD Meter?
Thumb throttleWhat other bits do I need while I am ordering and any things I need to specify to make sure I get the correct bits.
His bike is for sale now in London. Here's a link to his ad, where he gives a bit more info about it:chas58 said:Nice summary motomech
Wow, 350rpm on a Q100 and no pedaling? That sounds like a lot. I guess it is doable; I run a 300rpm version at 24mph, and a 328rpm version at 25mph (both with a couple hundred watts added by pedaling). I wonder where the weak spot is – probably the controller. 20amps sounds like it is pushing it for this motor.
d8veh said:His bike is for sale now in London. Here's a link to his ad, where he gives a bit more info about it:
http://www.pedelecs.co.uk/forum/threads/25mph-sine-wave-mountain-bike.20238/
