How hard would it be to test out running multiple controllers on a multi phase motor? I know with the 6phase motor i have from johns that its using 2 seperate sets of halls, how hard would it be to determin where the extra hall placement should be? Could it be tested on a rewound crappy hub motor which has more then enough teeth to wind probably 4 seperate 3-phase setups into one motor? Run it with 4 350w cheapy controllers to see how well it works. I know efficiency would take abit of a hit with out working everything out but it would be interesting to see if it works. Then its just a matter of finding a huge motor like Arlo is playing with but with a high number of poles etc. Atm 30-40kw seems to be the max attainable on "cheap" controllers. 15 controllers ~ 450kw+, its only 45phases
I dont know much about winding motors but is it possible to wind a motor only using 1 tooth on each side per phase or do u have to use 2 teeth per side winding clock wise and counter clockwise?
