The Road to Higher HP 100-200-500+ HP
Miles said:
Arlo,
I think you need to increase the magnet area, not decrease it.........
But I started with a bigger magnet area and evey time I decreased it the torque went up.....
I used a winding scheme from powercoco but maybe I need to wind it in a different way?
Arlo1 said:
Miles said:
Arlo,
Looks to me like you're running on reluctance torque and the magnets are basically air gaps.
major said:
Arlo1 said:
Miles said:
Arlo,
No making them thicker made more torque and making them higher N value made more torque as well.
:Edit although the lines of flux don't go thought the magnets like farfels example. Hmmm I will have to do some playing. I think the winding pattern is not right.
Power coco is not letting me choose WYE or delta... but I don't think that matters to much.
Miles said:
Arlo,
Was that drawing created in Sketch-Up, or something???
You seem to be using a mix of solid slot 6061 and Copper wire (10 turns)?
Yes sketchup. I have modified the magnets so many times in femm they have become ugly. The 6061 is in phase c I never changed it to the copper because phase c is not energized.
I think I need to understand the winding better to get this right maybe I need to split each stator slot into 2 and have it shared with another winding? I meen when I wound colossus there is a tooth on each side of the slot and each tooth had windings around them so 2 different windings in the same slot. How you label slots in femm is a little weird to me.
I was trying solid slot with aluminum but I can't seem to get it to work with any number of magnets.
I drew a lot of it in femm it self just the stator in sketchup. I can use something else but I don't think that's my problem. I will re draw it after getting measurements more acuratly for the tooth sizes etc. But as for right now I have something very wrong.
Sure, it's not causing the anomalous flux circuit. What happens if you only have a small gap between the poles (about the thickness of the magnets) and also take away the upstand of back iron at this point?
At the moment, you are concentrating the flux from the back of the magnets and giving it a preferred path between the magnets.
I think this is it I will double check later.
  • 60 tooth statoruntitled2.zip
Ok. I'll have a go at re-constructing this.
Maybe there are ways to optimise a Sketch-Up file before exporting to DXF? The file, as exported, is hardly worth messing with. Sketch-Up is a polygonal modeller - best used for "illustrations" only.
First attempt.......
Thanks miles. How does it know the stator length? Did you enter that? Or does femm know that? I mean how can it calculate toque without knowing that?
Miles said:
Is the stator inside diameter 200mm?
What is the stator length?
254mm id (10 inches) 5 inches long.
Don't worry about it I measured the stator slots and teeth last night more accurately and I will re draw it.
Sounds like you are building a radial flux motor of the same dimensions as a half-decent axial flux motor. With liquid cooling it might just work ;)
Oh, I might not need to build my own motor for the CRX - I was in touch with Evo-GKN and they said they will sell small numbers to any firm who has intentions to buy many more in the future. So if we can get a consortium together we can make the AFM140 the motor of choice for AC conversions. Then place a big order :)
An AFM240-4 in your machine should rip nine colours of shit through the competition :twisted:
I don't have your kind of money man lol. How much $ we talking? I really want to make a PM motor!
I used quick machine to regenerate a new one it seems quick lol
I think this will help me understand how to wind it.... I think?
I don't have that kind of money either :) But I'm stoked that they have gone from a flat out "no" to a "OK we'll consider selling you a motor". I'd love to turn an induction motor into a PM motor, and a nice big diameter one too.
What don't you understand about winding it? It gives you the winding pattern on the exPowerCroco site. Assuming you're going for a single layer winding, the coilspan is 15 slots - 5 slots per pole per phase - two iterations.
There is 2 more of the Cranes this motor come out of standing behind work..... I could make a 15 inch long stator if needed :)
