I'm starting to look at other options, while I wait to see if the KT 60V controller comes back in stock somewhere. Actually, in the long run, I could end up in the same place, but maybe in a different sequence.
Here's the alternate upgrade plan, which defers some of the $ to later, but that depends on some assumptions. My thought is to upgrade my motor first, to either the Leafbike or Ebikeling 1500W (I read Thundercamel's thread on this one), and keep the current controller and battery for now. Not sure, but possibly the increased efficiency will have a similar effect to using my current motor and higher voltage. My apprehension comes from reading Neptronix's thread on the Leafbike motor and that you need a lot of battery to support it. I'm wondering if that's because you'd ride it harder and pull more current. Anyway, if I'm going to kill my battery in short order by going this direction, then I'll need think about it some more. If I do kill my battery, I'm wondering if the increased performance of the motor would be enough so that I would just replace the battery with one with better cells and stick to the current voltage.
Any thoughts or information from folks running either of these motors at 52V would be appreciated (climbing ability, typical currents under load, etc.).
PS. The upgrade 52v pack I'd be getting once my current pack is exhausted would be in the same UPP hard pack, but with Sanyo 3500 cells in a 14S8P configuration; 40 amp, 120 amp peak, 28 AH. I'm hoping that's enough battery for either of the two motors.
