Alan B
I would add one more cell and make it certain instead of that close. Hopefully that won't create a space problem.
bakaneko said:how about checking out ERT? btw, i know you dont want to buy a new motor but looking at this modded CYC X1 Pro by ERT. He was hitting 45mph at like 2.5kW, 50mph at ~3.1kW that is some crazy efficiency.
Alan B said:I have some big triangle batteries, they are pretty heavy. Sometimes I think I'd be better off with some smaller batteries and parallel range extenders. Like the Luna Mighty Mini. If I have a 6ah mini and a 14 ah shark then I can have 6, 14 or 20 ah for the trip, and minimize weight. Configurable.
I thought the consensus was that he is an extremely unreliable supplier?bakaneko said:how about checking out ERT? btw, i know you dont want to buy a new motor but looking at this modded CYC X1 Pro by ERT. He was hitting 45mph at like 2.5kW, 50mph at ~3.1kW that is some crazy efficiency.
https://electricrt.com/e-r-t-12-mosfet-3000w-sinewave-controller/
https://www.youtube.com/watch?v=YUHUDEtQqjU&t=0s
john61ct said:I thought the consensus was that he is an extremely unreliable supplier?bakaneko said:how about checking out ERT? btw, i know you dont want to buy a new motor but looking at this modded CYC X1 Pro by ERT. He was hitting 45mph at like 2.5kW, 50mph at ~3.1kW that is some crazy efficiency.
john61ct said:No, keeping your money, never delivering the goods, never telling the truth about availability, zero support before nor after sales, complete radio silence for months at a time.
john61ct said:Satiator 72V model starts at minimum 20V, so 4S for most LI chemistries, 5S for LFP.
max is 103V
48V version is 12 - 63V
Both are 0-360 watts, so their rated amps max only applies when volts are lower.
Well their published specs do state various minimums, maybe your experience applies to earlier firmware?st35326 said:john61ct said:Satiator 72V model starts at minimum 20V, so 4S for most LI chemistries, 5S for LFP.
max is 103V
Incorrect, Im using the 72 volt version on an 88v and 12 volt pack. Itll charge about anything below 103 volts you just manually program the charge profile you want.
john61ct said:Well their published specs do state various minimums, maybe your experience applies to earlier firmware?st35326 said:john61ct said:Satiator 72V model starts at minimum 20V, so 4S for most LI chemistries, 5S for LFP.
max is 103V
I reckon it would be to his advantage for Justin to tout maximum flexibility. . .
E-HP said:Alan B said:I would probably stick with the Phaserunner / CA3, but the controller package you link looks interesting and cheap enough so it may be a good experiment to document it for others. First I would search and see if others have already done work with it. And consider the entire investment, plus your time completely "at risk".
Well if it's for the benefit of the forum, then I'm all in! But seriously, I have no problem with the "at risk" part, since it's not about the money, but that it fits the theme of my economy build, so if I can get the features that I want economically, then I'm willing to give it a try. I'll do more research and if this is the best option (bang for the buck), I'll go for it. I'll keep the Phaserunner on my list for the next, non-econo bike though.
Not sure yet since I'm just starting to research. I think 2s and 6s would get me to 60v and 72v, so I guess a couple of combinations I guess. I think I'll spend while checking out the new controller and dialing it in, and by that time I'll have a better idea. :thumb:Alan B said:Great.
I gave some lipos to a friend, he isn't using them, perhaps I should see if he still wants them. Mostly 6S5AH Turnigy. What are you looking at using?
(waving, squeaking "ooh ooh")Alan B said:I also have a 14S balancing charger that I haven't used in awhile. Hard to find those anymore.
