A Waste Of Money Or A Great Deal???
48V 13Ah lithium ion Bottle ebike battery pack with charger
1. Rated capacity: 13AH
2. Voltage: 48V
3. Charging Voltage: 54.6V
4. Discharge cutoff voltage: 36.4V
5. Cell: 18650 (13S5P) ISR18650-2600mAh(LiMn2O4) This battery pack include 65pcs 18650 cells
6. Standard charging: 0.2C constant current(CC) charge to 54.6V, then constant voltage (CC) 54.6V charge till charge current decline to ≤0.05C
Cycle life:Discharge capacity (500st cycles) ≥60 %( Min Capacity)
7. Continuous discharge current: 30A
8. Pulse/Max discharge current 70A
9. Max charging current : 5A
10. Charging temperature: 0~45℃
11. Dischargeing temperature: -20~55℃,batery management system to prevent overheating
12.Operating voltage:36.4V~54.6V
13. Diamesion: 91x435mm(diameter X heigh)
14.Weight of battery pack:About4.25 kg
Standard charging 0.2c, 13ah pack so that works out at 2.6a
Max charging current 5a
Which rate is correct ? it's going to be 3 hours vs 5 hours to charge.
The pack looks like it will voltage sag if I just look at it.
It pays to get a decent 18650 pack or go the lipo route with an rc charger and a server psu, these cheap ass packs won't give a 350watt hub motor a licking.
Get someway of monitoring voltages if it feels saggy then it's flat as a pancake or the pack is shizer.
Junk.
But what do you want what are you trying to power how much you want to pay level ground up hills what controller you trying to run as that tells us what the demands on the battery
Battery needs to know what has to power. Right ?
