SniperGaulois
I am making a 14s8p battery with copper tracks welded onto nickel strips which will be spot welded onto the batteries. My nickel strips are .1mm x 8mm, and every battery has a single strip that transfers onto a central copper wire.
Unfortunately, the test on the nickel, using HCl is showing rust, i dipped it 10 minutes in HCl and left it to on a shelf. it has gone rusty and clearly looks like steel.
previously, every 8 batteries had 8 "nickel connectors" which could transport about 8 times 5 amps, so 40 ampers maximum, as far as i was aware...
I think i have to revise that to 8 times 2 = 16 amps safely.
Please check that my maths is right and that i am indeed shafted if i use the fake nickel strips.
