Harlequin Hawk
100 µW
- Joined
- Aug 12, 2016
- Messages
- 8
Greetings all,
I am a Trying to build an Mountain/Carving E-Board and this will be my 1st Attempt. I have already picked out a few of the parts, but have yet to pick others and would much appreciate any feedback. I am Trying to spend money Wisely, Important stuff i am willing to spend more on otherwise ill go cheap. Also for now im only getting one motor but will upgrade to 2 eventually. Also i have a Machinists friend who will be milling a Motor Mount for me.
Here are the parts i have/planning to get so far.
Motor:
Turnigy Aerodrive SK3 - 6374-149kv Brushless Outrunner Motor (US Warehouse) . I wanted a high Torque Motor and would offset it with a 3:1 Ratio gear setting for higher speeds, is what i read around the web would be right?
Transmitter/Receiver :
HobbyKing® ™HK-GT2B 3CH 2.4GHz Transmitter and Receiver w/Rechargable Li-i (US Warehouse) . This is what i read everyone else uses. Its cheap and works.
Gearing : ~3:~1
Small Pulley 5M25T
Large Pulley 80 Tooth Drive Belt Cog 12.7cm/5inch Diameter Machinists Friend will be drilling the holes and possibly taking out the excess metal.
550mm-5m-15mm Belt
I do Realize that I could have gone for Less Teeth and same Ratio of gears, or did i fub the math on this XP ? but these are cheap so there you go lol XD
This is where i need help.
ESC/VESC:
From what i have read here I want atleast 20% above the motors peak. In my case 70amp is my motors peak, so 84 amp minimum per motor? And since ill be getting 2 motors eventually i was wondering if i could get like a 200amp ESC and hook up 2 motors to the same ESC? If not any suggestions for a moderatly priced ESC would be very welcome. Any advise really would be great.
Batteries:
So ive read here that Voltage gives the motor "Power" while Mah is how long that battery will last. but whats the C=Discharge rate mean? I am weary of pricing and there are so many to choose from. Lipoly, nimh, nanotech BLARG!!! I am going to keep looking and narrowing them down but any suggestions/info here, are again very welcome
I think that is everything.
Ill also add the Board im making just in case. I think its pretty good =D
Mountainboard Deck, Ten Ply Canadian Maple, Drilled Again Mr Cheap wins the day lol
Trampa trucks I wanted good Trucks that would last so i splurged a bit here.
Trampa Hypa Hubs I wanted the Wheels i bought to fit without issue so i also purchased the wheels, spacers, and Bearings from Trampa. The cheapest ones of course lol.
Motor:
Gearing : ~3:~1
Small Pulley 5M25T
550mm-5m-15mm Belt
ESC/VESC:
Batteries:
