Matador said:I also ordered mine (4 kits to experiment, so 400 caps for 200 cells... might just start playing around with laptop cells to compare with my previous experiment using laptop cells and springsteel nickel plated....) Not sure yet if i'll try it on my VTC4.
In the meantime, I made some calculations to estimate total resistance of pack with Vrizund kit.
All conductive parts are stainless steel....
Made measures from video. I estimated that worst case scenario, the sping contact post are 3 milliohms each.
The interconnecting bussbars (2.5 cm long hole to hole ; 8 mm wide and 0.5 mm thick) are also stainless steel.
So if I make a 14S10P pack out of 140 Sony VTC4 cells I get the following (I don't want to get into details of calculation.... bit too complicated to explain, but using ohms law, resistance in series law, resistance in parallele law, etc...)
Each VTC4 cells is 23 milliohms DC internal resistance.
14S10P in ideal world where connection would have no resistance would yield at total pack resitance of 32 milliohms.
With Vrizund kit, that would come to 64 milliohms (14S10P with each 10P pack with 2 rows of 5 cells, and 5 strips to connect each 10P subpack to the next one).
With Vrizund kit, if I change the Stainless steel for copper interconnecting strips (keeping exact same strip dimensions), that would come to 41 milliohms.
Is this 14S 10P configureation (each 10P 2x5 cells with 5 strips interconnecting each subpack), the contact terminals are responsible for adding up 8.4 milliohms to the pack, while the inteconnecting strips add a total of 23.4 milliohms to the pack, but only 0.567 milliohms total if swapped for copper interconnecting strips of same dimensions (25 mm long x 8 mm wide x 0.5 mm long).
So pushing my BBSHD controller to maximum 30amps, id' see a 1.94 voltage drop on the original Vrizund kit with that 10P pack... Compare that to 1.23V drop with copper bussbars or with 0.96V drop in an ideal world (using supraconductors if a could, zero resitance !). Quite acceptable a priori.
I wont go into details. While this might seem like adding a lot of resistance to the pack, it shows because my cells are of low intrinseque resistance valures.
For instance, do the same with Panasonic GA cells (around 38 milliohms each cell https://endless-sphere.com/forums/viewtopic.php?f=14&t=73701#p1112249) and you get for 14S10P in this architectural configuration :
53 milliohms ideal world (resistance-less connection - zero resistance) --> 30A drop of 1.59V (10P pack)
85 milliohms with original Vrizund kit --> 30 A drop of 2.55 V
62 milliohms with Vrizund kit but swapped bussbars for copper instead of stainless steel. --> 30A drop of 1.86V (10P pack).
Pushing the example to the extreme, using old laptop cells (let's say 150 milliohms each cell), it becomes even less apparent :
210 milliohms ideal world (resistance-less connection - zero resistance). --> 30A drop of 6.3V (DONT PUSH 30A on laptop cells !)
242 milliohms with original Vrizund kit --> 30A voltage drop of 7.26V
217 milliohms with Vrizund kit but swapped bussbars for copper instead of stainless steel. --> 30A voltage drop of 6.51V.
Ordered 4 kits.... Dunno if it will be okay at 30amps, but it will most probably work wonders with lower power eBikes too (10-20A).
DISCLAIMER : These numbers are estimations I made. I migh be pleasently surprised by better conductivity. Yet, there still the question of proper contact pressure to be explored in practice. But anyhow I have 2 uses for 18650 : eBikes and small (<100Ah) Power banks...
BTW, I just notice, with my 14S10P VTC4 cell pack, if my 10P subpack are 1 row of 10 cells instead of 2 rows of 5 cells, and IF I then put 10 interconnecting strips between each subpack instead of 5, then the SS stips of the original Vrizund kit would add 11.7 milliohms instead of 23.4 milliohms. Fot copper bussbars, it would be 0.284 instead of 0.567 milliohms
That would mean :
32 milliohms ideal world (resistance-less connection - zero resistance). --> 30A drop of 0.96V (drop inherent to cell IR only)
52 milliohms with original Vrizund kit --> 30A voltage drop of 1.56V
41 milliohms with Vrizund kit but swapped bussbars for copper instead of stainless steel. --> 30A voltage drop of 1.23V
You are just truly amazing! Thanks
