thundercamel
Found the image I was looking for. If the cells were bad, then their voltage would sag further the more amps that you try to draw from them. If they aren't bad, and their voltage is staying where you expected, then the system as a whole is either being limited:
At low speeds by the phase amp limit (set inside the controller)
At mid speed by the battery amp limit (set inside the controller)
At high speed by the voltage or back electro-magnetic-field (BEMF, which is generated by the motor spinning) equaling the voltage being sent to the motor. The voltage limited portion is affected by the Kv or winding speed of the motor, and by the voltage of your battery. In your case, you could just change your gearing if this is what's limiting you.
We're confident in your 1000w reading, correct?
