tsellers
That is the same display that the M600 uses as well. I like the size as it makes the Frey M600 less obvious as an eBike at a quick glance, but like smartphones, it is probably polarized. That means I also cannot read the display at all while wearing my prescription polarized sunglasses, and when I slide them up so I can read the display, I cannot read the numbers for the battery or trip line unless I bend into a potentially dangerous position. This problem is worst when I want to see how many amps I am pulling on specific hills so I can optimize the adjustment my PAS levels to conserve power. The solution might be to get some non polarized prescription sunglasses, then everything should be readable. Another work-around that would allow the use of polarized sunglasses that may work: turn the display 90 degrees. It looks like the form factor of the mount might allow that to be easily done, so I may try that first.
