MadRhino
ScooterMan101 said:With a heavy hub motor on a bicycle frame , I would have some custom made torque arms for each side, long enough to go far up the chain stays so as to lessen the torque loads on a bicycle's small , thin, drop outs.
The droputs of the Banshee Sream are huge and half inch thick. Tight fit torque plates 1/4 steel screwed on each side are best, either deep dropout, through axle, or thicker pinch type. Torque arms are common on low power, cheap kit builds. For high power, torque arm is the ugly temporary solution. Not that they can’t be made strong enough, but a high power build deserves the extra work to make it neat and reliable on the long term. The QS 205 is delivered with torque arm, yet best that can be done is throwing this to garbage and spend the time to make the real thing.
