It removed the short across the input because it removed the path for current to get anywhere past that point.
There is something else beyond that resistor in the circuit that is causing the short. I don't know what the specific circuit is in side there, so you'd have to trace it out to see where it goes.
Keep in mind that if you are measuring resistance across a battery input port, you won't read a real resistance with a regular multimeter because there is a voltage present on it from the battery.
If that's not how you are measuring, you'll need to show / state exactly what you are measuring and how, and where, so we can help you figure out what the problem might be.
If you're measuring at the input to a separate board, without the battery attached to it at all, then that should show a real resistance, but we still have to determine the circuit to see what might have failed.
The most common parts that fail short circuit are capacitors (elecrolytic or tantalum), reverse-connection-protection diodes wired directly across an input port (as opposed to those placed in series with one input wire, which won't cause a short across the input), and switching circuits made with FETs (but they are not normally on the *input* side).
izzzzzz6 said:
Now i'm a little confused. It appears this is not a 5MO resistor but a very low value current sensing resistor. Are these designed to go short? Removing it removed the short across the charging power input but if this is correct it is supposed to be almost dead short.
