I have a BMC motor that appears to be having some hall sensor problems. Motor makes very sad grinding noises when power is applied, but turns freely forwards and backwards with no power.
I had probed the blue, yellow, and green wires while turning the motor backwards to see the voltage change and found 1 sensor that was constantly reading 4.8 volts.
I thought, ok, no problem, replace the sensor then be on my way. Replaced the sensor, and found the problem was still present.
I inspected the wiring harness to find that it was worn and possibly shorted, perhaps taking the sensor with it. So I replaced the entire wiring harness (phase and sensor wires) with brand new ones - taking a considerable amount of time. I replaced the sensor for good measure incase I had blown it by sending power to a phase wire shorted to the sensor.
Still, exact same problem as before. Motor makes very sad grinding noises and sensor constantly reads 4.8v no matter the position of the wheel. I replaced the sensor with a Honeywell SS41 and the wiring harness completely. Sensor shows conductivity to the correct pins, and other 2 sensors behave as they should. Double checked order of the wires I reconnected to rule out a miss-routed wire.
I have no idea what else to do. Any advice?
