Chalo
100 TW
flippy said:prismatic is troublesome to use as you need massive steel supports to compress them. that often negates any advantage they might have.
i'll switch to prismatic/pouches once they start making professional power tools with them.
My 1.2 kWh pack made from prismatic cells has two 1/4" aluminum plates held together by 4 sticks of 1/4" all thread. Compared to 500+ strips and welds, that was a cakewalk. The cells are rated for 500A peak, but I discharge at 35A peak, so any kind of compression is probably only a formality. But it gives the pack some structural integrity, so that's worthwhile.
My cordless drill has 1/10 the amp-hours of my bike's pack. So it makes sense that the cells are about 10% the capacity of the ones in my bike. Would it make sense for the pack in my cordless drill to be made of highly parallel groups of 250mAh cells? No, it would not. The same way it doesn't make sense to make similarly parallel bike packs from lipstick cells.
