Obviously they will reco their own, which might be just fine.
I meant get the detailed specs on the controller
"what is the maximum voltage it will work with, without causing the components too much stress?"
Maybe also "what (lower) voltage will be a good balance of performance and give me a nice long range?"
since you still have not answered which of those factors is of most relative importance for you.
Look at the Grin simulator, see if your gear is in there maybe you can see what speed vs range you get for your commute patterns at the two different voltages.
Or maybe others more knowledgeable than I can advise between the two choices, might be worth starting a new thread for just that topic when you know your options.
But really, you need to give more details about your use case and priorities or we're just stabbing in the dark.
