Elektrosherpa
- Joined
- Feb 7, 2021
- Messages
- 386
I also think the points "thoroughbred" made about the "NC" and "B+" connectors are reasonable.
Indeed the screw labelled "B+" was fixed, and the one on "NC" was loose.
So today I connected the necessary cables, as "Dui, ni shuo de dui" suggested, and I connected my source PLUS to "NC".
After connecting the "PWR" wire to the source, too, the bluetooth thing indeed started blinking,
and I could connect as well the smartphone as the laptop.
The software still looks kind of crappy on the smartphone, nothing fits, and the screen orientation cannot be changed.
But on the laptop it looks fine.
The parameters were already set, e.g. the angle was already to "85" as it should be.
In this "idle" state, my power supply indicated only very low power consumption (just about 0,025 A), so I dared to turn the throttle - and - tataaaa... the sprocket started to spin. I carefully turned it more, until up to 4,5 A (what resulted in a motor rotation rate of close to 3000 rpm), without any signs of weakness or failure.
Therefore again MANY THANKS to all the helpers !
Now I will have a closer look at the settings, and then the serious (but more familiar to me) work will start:
1) getting rid of the combustion engine
2) putting the motor and the controller into the frame
I already found a mechanical thing which I don't like:
The sprocket which came with the motor sits very loosely on the shaft...
As well axially, as radially, there is way too much tolerance/clearance (not really sure which is the right word).
I guess I could eliminate the axial tolerance by adding shim plates-but the radial clearance ?
