speedyebikenoob said:
Yup I have the cheap stock controller lol, don't think it has anything fancy going on in it. So when the controller shuts off when you're really hauling it it's probably because the controller senses the internal heat inside the casing is too high right? It's not for the motor?
It's probably not even sensing controller temperature--like I said, in the generics there's literally nothing sensed or limted except battery current (well, voltage usually has an LVC, and occasionally an HVC). (there are some that do, but most do not, until you start getting into more expensive versions, like, for an instance here on ES, the Powervelocity series, which are still "generic" controllers, but that have been customized, and have more features than typical ones. )
If a motor wiht hall sensors gets hot enough, the hall sensors can begin to fail, sometimes just temporarily, sometimes permanently damaged, and that can cause a sensored controlelr to stop working correctly (or at all), because it isn't gettting position from the mtoro so it can't send phase current in timing that works.
If the FETs get hot enough they may stop working correctly--but often this is a complete catastrophic failure.
If the capacitors get hot enough, they may leak or explode.
If the MCU gets hot enough, it might stop working like the hall sensors, in a temporary way, but past some point it'd just fail permanently. Similarly, other non-power-handling semiconductors in there could do that.
But...the most common thing that causes shutdown while pulling a lot of power is the battery. The cells sag in voltage more then, and if any of htem are weak enough they'll go below the LVC of the BMS, and that will shutdown everything, at least momentarily. If there is no BMS, or it doesn't go quite low enough to trigger it, it could still go below the LVC of the controller (if it has one), and the controller will stop working utnil voltage goes back up once the load is removed.
