Nino1967 said:
There is a rear wheel motor CSC 1500W.
The controller is a 48V - 35A.
The battery is a 48V, 20A.
At the moment, the maximum speed is 35 km/h.
Does anyone know how to increase the speed by having different settings, or a different controller or something else?
Depends on what is limiting the speed, and what your specific riding conditions are.
Does the wheel spin noticeably faster at full throttle when it is off the ground than when you are riding? If so, then it is not limited by the controller as a speed limiter, so there are various things you can do to increase speed without replacing the controller, depending on your conditions.
Assumign the above, are you riding only on flat roads, no significant winds? If so, increasing system voltage as noted by E-HP to a 52v battery (14s) instead of a 48v battery (13s) will increase top speed a small amount.
If you have uphills or slopes or winds, it may require more power (generally from battery / controller current), and that might require changing your controller (and battery).
Also note that if your battery really is only a 20A (not 20Ah--very different thing) battery, then it probably can't provide the current the controller needs to do it's job at higher loads without a lot of voltage sag, which takes away speed. In that event, a better battery that can handle more than the load required of it would help with this problem, and may (depending on conditions) give you a little more speed.
Since it's a somewhat complicated relationship between conditions and parts on the system, you can experiment with the http://ebikes.ca/simulator to see these, and then simulate your actual conditions and something like your system, to see what you have to change to get the results you want.
