raylo32
One more note to those looking at maybe getting a Photon and maybe coming from TSDZ2. Photon needs to be rotated into the downtube since it doesn't have mounting hardware to hold it in place otherwise. This can be an issue for many bikes that have shift cables running down the downtube or brake and shift housings exiting internal routing ports right where the motor needs to go. In these cases you will need to create some sort of standoffs to ensure the motor does not crush down on these things. I am a little surprised that the installation instructions don't address this or that there is not some verbiage somewhere in the product information about this issue. I know I was surprised coming from a TSDZ2 that had no interference issues with my shifter cable. I have never had a BBS motor but I believe those also have hardware the fixes the motor. So, buyers beware... or should I say, buyers be prepared... to figure out a workaround on your own if you have a bike with anything other than a bare downtube where Photon will touch.
