I think you first need to address the setup posted above from Justin to get the device operating in the proper range. Then I suggest you pursue the gain settings described in the other post above.
You could try a pot (or limit switch) with AuxPot configured for PAS Assist Level so you could dial in the desired assist - but only after you've done the above.
If you have only a single chainring and have a low cadence on hills, then there are going to be issues and the AuxPot input may be your only route. Normally, a hill is met with a downshift and higher rpm which gives more assist and up-the-hill you go.
