DanGT86
Nice work on the brake bracket. How does the suspension react when you hit the rear brake hard? Does it bounce or chatter the rear tire when it locks up?
I rode mine around for a bit with no rear brake and it was such a relief to finally have one again. Just an FYI, That caliper mount on the swing-arm is at the standard IS location like an oem bike so you can always use a post mount caliper and adapter in the future. The only issue is that its located for a 150mm wide hub. I figured its a lot easier to add spacers for narrow hubs.
I wouldnt hesitate to tie a bike down like that motorcycle in a truck. Its so light that you wouldn't need to compress the forks very far to get adequate tension. I think the issue with fork stress is more of a problem with full weight motorcycles. You have to pull them down so hard to secure them that you end up torturing the bottom of the fork stroke where it wasn't designed to be for long periods of time. Another often overlooked thing is the premature wear on suspension parts when hauling vehicles because the suspension is still working while being hauled. Again a bike is so light that without a rider its probably not stroking far or at all. If it were a 3000lb racecar I would block it under the frame when hauling it to save the shocks.
That bike looks fun!
