skeetab5780
Unfortunately I went the other way on the fork, even though I think all of you are correct on going with the triple crown. None of you chimed in fast enough since I already jumped the gun and bought a single crown two days ago.
I ended up getting a rock shox brand for $379 so I could use my 15mm thru axle wheel already obtained a year ago from another build. Lets hope its enough.
Color Black
Weight 2082g
Brake Usage F/R Front
Fork Rake 40mm
Axle to Crown Length 529mm
Crown Race 30.0
Steerer Tube Length 265mm
Brake Type Disc
Wheel Size 26"
Travel 150mm
Front Hub Spacing 100mm
Front Axle Type 15mm Thru
Spring Dual Position Coil
Wheel Mount Center Offset 0mm
Lockout Crown Mounted
Defined Color Black
S.H.I.S. Clamp Diameter 28.6
Item Name Sektor
Steerer Type Straight
And yes Voltron I think you are correct about soldering versus crimping, but the XT60 and XT90 connectors are solder only if I remember correctly, I cannot see a way to crimp them. If I was using Anderson connectors I would crimp them. Also I run a electrical supply house so I sell almost every one of those crimpers in your pics!
Yes Nutspecial! I love this bike but have a feeling im never going to have a big enough battery. I cannot wait until I can rip up some hills around here that you would normally need an ATV or dirt bike for!
Now about modifying the frame, you are correct. I can alter the shape of the battery pack and get all three to fit in the triangle, it will look a bit off but it would go. Id have to mount one of them above the shock pivot and the other two to the bottom triangle.
Do you honestly think cutting into the tubes just that little bit would make the frame that weak? I feel it would be doable with a tig welder on hand. Aren't most of the forces on the bottom tube on the bottom half of the tube?
Color Black
Weight 2082g
Fork Rake 40mm
Crown Race 30.0
Brake Type Disc
Wheel Size 26"
Travel 150mm
Defined Color Black
Item Name Sektor
