Racer_X said:
DrkAngel said:
Limiting charge-discharge to between 3.7V and 3.9V provides ~55% capacity ...
with an estimated 800% battery life! (possibly more?)
Great info! I have noticed that when I charge to 3.86V = 46.4 on my 12s LiPo I have quite of bit of range with my battery packs.
My 10ah can go about 6km and my 15ah can go about 10km before it hits 3.7V OR 44.4v on my 12s LiPo.
If I was to experiment and use one brand new pack of LiPo batteries at these levels from the very beginning it can theoretically last at least 10 years before significant capacity loss start to show. That is a long time with the same pack!
I've seen no investigation as to whether:
lower voltages prolong life
vs limiting use to energy rich regions of voltage prolong life?
Staying within these energy rich regions seems more logical!
This is the capacity map I made from 2600mAh Sanyo cells I've been recycling.
It concurs fairly nicely with the above LiPo graph.
3.7V to 3.9V looks optimal, but I have been charging to 4.05V so as to take advantage of that last capacity bulge.
4.05V figures to a ~300% cycle life over 4.2V at a minimal capacity loss.
Tougher for me to figure are the Recycled LiPo I acquired.
They have an inexplicable capacity bulge at ~4.12V.
I had to run the test twice!
Limiting charge to 4.05 is most effective at prolonging life cycles ... but this neglects the storehouse of energy between 4.10V and 4.15V.
My solution will be to typically charge to <4.05V for normal use and occasionally charge to >4.15V for longer trips etc.
My standard pack holds 7s12p = 25.9V 25.92Ah but I typically use <5Ah for around town errands.
