MitchJi
Hi D,
If the belt works its a great idea.
How are you going to adjust the tension of the secondary belt?
Are a wide range of pulley sizes and belt lengths available?
I'm still concerned about the belt holding up in your application. Every time the wheel hits the ground if the motor is turning the rear wheel faster than the bike is moving there will be a jolt through the drive line. This sounds good though:
http://www.cycledrive.com/faq.html
But these are concerns:
Is the belt as strong as a chain?
The Kevlarâ„¢ reinforced CDrive Belt is stronger than any bicycle chain; it will not stretch or break on a bicycle.
Does the belt skip?
The CDRIVE system will not jump or skip under any normal pedaling pressure. In some circumstances, a strong and experienced rider 'putting the system to the test' might be able to skip the belt. This is not recommended as it can lead to shortened belt life.
Can the CDrive belt system work on any bike?
The system is not recommended for Mountain bikes or other situations where conditions could be very muddy.
