lol, i have no hang ups with the arm, im ready to ride it again but the setup needs to gain a little trust back
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
i dont mind ending up on my arse if i goosed it too much :lol: but last ride didn't end up the way i planned
I have gone from 5 to 1 (of10) on throttle response so it should be much better next time out, but im a little worried that i can't cap the current using this method, if i can't limit the power to something sensible which it seems i can't? the throttle needs to be bloody good at modulation, Matts had good sucess with the straight up no interference setup ie, servo,magura,esc so i thought i might try that and see if can gain enough room to at least get a pack kill in there, just in case
![Shock :shock: :shock:](/sphere/data/assets/smilies/icon_eek.gif)
I don't know when the throttle will arrive, if Matt looks in maybe he can give me a heads up and im off now mate, due back to work in september
i think i was a little naive going straight to the 3220 and hv160, i had thought that i could limit the power with Richards box and that the overkill would help to keep everything at usable levels, ie, heat etc ,tbh i only need limited power, with my current setup of single reduction then chain i may even have got away with a hv110 and a 3210 but i didn't try it
![Rolling Eyes :roll: :roll:](/sphere/data/assets/smilies/icon_rolleyes.gif)
i need to find a happy balance that my puma gave me but doesn't fall to pieces if you jump it :lol: we'll know soon enough i guess, i have put on the 72t from 80t which should help also.
If i fit my caps now and run i have to use fech's box, and run it on full to help the esc, it seems a waste to risk blowing either for a ride or two.
funnily enough jozz suggested i lace up my spare rim with a xlyte 4 series, just for a quick ride when the rc was out of commission - i've thought about running one with a lyen at say 75v 50a but i dont have the money spare to setup for that at the mo.
i tried the fuse in the black hole ? i'll look at the other one and see if it goes in, would be nice not to have that crack each time i need to power up
i fear i've missed the season again, forest is soaked with all the rain and my motor phases are right under the bike, at the mo i feel that's there no immediate answer to a controlled setup, although i have my pedals back from crank drive the rc setup doesn't play as well as a hub with assist, but does a damn of fine job of yeehah.
D
