liveforphysics
100 TW
AussieJester said:Even if you could get the wires off Luke, how do you suggest a cap be soldered to the negative and positive on the pcb where the '+' & '-' wires connect, seeing they are a good inch and a half apart, the legs of the caps would need to be extended to even reach. My first attempt as you know was to solder them directly to the top of the input leads resulted in a popping the legs hence my use of the 3 caps on a piece of pcb board which as we know was unsuccessful at ridding the high ripple. Its simply physically impossible to attach where you suggest Luke without lengthing the caps legs which defeats the purpose doesn't it?...
KiM
It would still be the shortest path to the FETs (even if you had to lengthen a leg). If you have space for it, fitting some substantial caps in there would be a huge help, and/or ripple eliminator.
