Mark Stosberg
I need some some debugging help.
I recently got my wife's electric Yuba Mundo back from the bike shop after they put some new tires. I know and trust the bike shop folk, but they don't have e-bike experience. The mechanic said he test drove the bike and loved how it rode with assist. I presume he did that /after/ he put the new tires on.
When I was riding it home, I notice the front fork with Nine Continent front hub motor was vibrating badly when the throttle was engaged, but I assumed the issue might be transient. The bike was built in 2010, and there have been various hiccups along the way that seemed to self-recover, and I thought this might, too.
Once I was home about 3 minutes later, I inspected the front more closely to see if anything seemed amiss. I found a couple things.
The hub motor has small torque arm that connects back to frame to help hold the wheel in place. The nut was missing off the back of the bolt there, and the bolt was going through the whole at an angle instead of straight.
Also, the hub has a small bar next to it that usually points straight down. It was about 20 degrees off. The bar can be seen here in a photo pointing straight down, pre-repair:
https://farm9.staticflickr.com/8379/8681520811_9eed95e9e8_o.jpg
I reproduced the bad vibration issue for my wife at home, but soon after that, things got more "interesting". The hub quit turning at all when the throttle was engaged. I'm not sure if this related to the vibration issue or not.
Here's what I've done so far to diagnosis why the hub isn't spinning:
From my multi-meter tests so far, I'm concluding that there's a problem with the controller, since the battery has voltage out to the controller, but the controller has no voltage out to the hub. How could this be related to the vibration from earlier or the loose connection I found? Are they all related, or all there multiple issues going on here?
For an additional test of the hub, I thought of connecting it directly to a battery source to confirm that it spins with juice applied. For that, I will need to be a little more careful to make sure I don't get my wires crossed.
Sound advice and wild speculation are welcome.
Thanks,
Mark
- I used a multi-meter to confirm that the battery is working. It's putting out about 39 volts, and it's a 36V system that works from about 42V to 31V. I have a 15Ah LiFePo4 battery.
- I have a Cycle Analyst, and it also reads 39V.
- If I unplug the hub motor and test the DC voltage arriving at the hub, it's just a trickle-- millivolts. The wires are blue, yellow, and green. I'm not sure what's what, so I just checked all the combinations.
- I have an Infineon 35A controller. As I looked it closely, I did find the connection to the hub was loose and tightened it, but that made no difference.
- Next, I used the multi-meter to check the voltage coming /out/ of the controller headed towards the hub. Again, the wires are blue, yellow and green. Again, I just see a trickle of millivolts there, with and without the throttle engaged.
Thanks,
Mark
