bzhwindtalker
Hi guys, if you need a replacement 14T sproket, please send me an email, I have such a hard time to keep track of usernames Sorry about that
Best regards, Adam
Best regards, Adam
TorEddy said:Haha.. yeah the trails look pretty similar. Where are you located?
Guess you are riding the 64's big brother then :wink: Looks fun!
Joe said:I have a little wobble of the rear cog freewheel, but not a lot 1mm or so with no belt installed. No Loading.
With the belt on and tensioned, the wobble is gone.
Is this what you are calling the clutch.
How much wobble do you have?
Did you take off the rear wheel. There is a spacer which has to be fitted the correct way round.
One side pushes against the inner bearing shaft and the other side is against the frame.
I can‘t remember which way around it was, but I know it must be fitted correctly.
There‘s no alignment of the rear wheel, as it‘s all fixed.
Can you take a better photo of the tensioner. You seem to have a massive up and down scratch. To me it looks like the chain even hit the swinging arm bolt and goes 3 cms lower.
Are you sure it‘s installed perfectly.
I had another thought. Is the chain worn out. Have you got a lot of sideways movement. Is this a sign of a worn chain.
Dirty-Kurty said:Joe said:I have a little wobble of the rear cog freewheel, but not a lot 1mm or so with no belt installed. No Loading.
Yeah i mean the freewheel just used the word. If the chain has some tension it doesnt wobble but it doesn't move clean. I have like 2-3 mm wobble...
I took of the wheel but the problem was before and I doublechecked this first.
If I throttle in Mode 3 the chain moves a Lot up and down, it looks like there is to less tension on it. Maybe i order a new one? Its my first chain. I Check the sidewaymovement tomorow.
The problem came after cleaning the tensioner. Na thought was that i didnt install it correctly. Maybe there is a special distance to get a correct chainline.
I hope the pictures are better.
I know exactly where that is.briangv99 said:Quick lunch time ride to break up the day
Still yet to make it up the super gnarly rock garden hill without putting a foot down, but reckon it's doable with bike the calibre of the LMX.
Joe said:It looks like you have no tension on the spring. Shouldn‘t the little end of the spring be on the other side of the bolt. I‘m not sure, Maybe someone else can confirm.
I remember that there is some real pull on the chain with the tensioner.
This is a picture from some months ago. Maybe you can compare the positions.
Joe said:Dirty-Kurty said:Joe said:I have a little wobble of the rear cog freewheel, but not a lot 1mm or so with no belt installed. No Loading.
Thanks to TorEddy. We can see some differences.
Your spring bolt. Why is it so long. It‘s 1cm longer. Look at the screw threads after the nut. Are you missing something?
The spring needs to be sitting on the spacer to be able to freely move. Looks like you are clamping the spring and not the spacer with the washer. Your smaller bolt looks a little bent and needs to be set up to look like the TorEddy bolt. Straighten it or replace it with a shorter bolt. You can*t screw it in any further as it will touch the roller.
Where is your spacer? This is a photo from my removed tensioner.
There is a 2nd spacer as well.
Joe said:Here are 2 pictures to compare the rear swinging arm of LMX64 to the LMX81.
Note the improvements on the angle of the rear suspension and the redesigned and strengthening of the LMX64 swinging arm.
It‘s a completely different setup.
I think LMX has made many improvements over the LMX81. I am sorry that it has happened.
Maybe it’s possible to up-grade the swinging arm.
what a small world! I definitely miss that bike. will pm youHK12K said:
Off topic, but I like the bike in your avatar. In fact I liked it so much I think I now own the bike in your avatar.
Greetings from Surrey. I hope that you have been well. Let me know if you ever decide to sell any of your other bikes. :wink:
How about you two getting together and having a chain verse belt challenge. Acceleration, top speed, and the climb.Cowardlyduck said:I know exactly where that is.briangv99 said:Quick lunch time ride to break up the day
Your on mate, that track up is super gnarly as you say, but the challenge is the first to make it up without stopping for sure.
Cheers
Interesting problem....and solution. I can't say I ever had any chain issues in the short time I was running mine.Mihei777 said:Hi. Interesting to know that somebody else having problem with chain tension. This chain tension issue been troubling me long time. First i had a too long chain (factory) and that was creating problem (that time i had also power cut problem, which stop motor for short period and then chain was jumping over tooth) . When chain was too long i tight normal spring pretension. Latest solution you see on picture. I have found this solution is best for me, but maybe dosent look so nice but it works. Here is pic.6F3B005F-6062-41D9-915A-200E070D5AF2.jpeg
