eMark
billvon said:Nope. BLDC motors are AC motors; the controller creates the AC. (Yes, I know, the letters "DC" are in the name, but that's because they are intended as a replacement for mechanically commutated DC motors.)
Is the alternating 3-phase sine wave of a BLDC and BLAC motor identical to the 3-phase sine wave of a traditional AC motor ???
BLAC motors specifically use electromagnets and rely on an integrated power inverter, rectifier and sensor ... https://www.motioncontrolonline.org/products/ac-brushless-motors.cfm ... So, would it be correct to say that a BLAC motor uses its integrated power inverter, rectifier and sensor to create the same identical 3-phase sine wave as that of a BLDC motor?Three-phase motors are motors designed to run on the three-phase alternating current (AC) power used in many industrial applications. AC electricity changes direction from negative to positive and back many times a second. The AC you get in your house, for example, goes from negative to positive and back again 60 times a second. AC changes power in a smooth continuous wave called a sine wave. Three-phase AC has three sources of AC power, all out of phase with each other. That means that no two AC waves are ever at the same point at the same time.
Does a BLAC motor generate the same unique 3-phase sine wave identical to that of a 3-phase BLDC motor? Is it possible that the 3-phase sine wave of a traditional 220V AC motor (e.g. alternating from neg-to-pos 60 times a second) is not the same as the 3-phase sine wave of a BLAC motor or BLDC motor? If so, then both AussieRider and John in CR may be correct depending on how one defines BLDC alternating 3-phase current.
Perhaps, in the sense that the sine wave of a 3-phase 220 AC motor is not the same as the sine wave of a 3-phase BLDC motor ???AussieRider said:The controller sends pulsed DC to the phase 1 coils, Then switches to phase 2, then phase 3. The confusion rises because there are 3 sets of "phase" coils but it's not 3 phase AC.
Here's a link for everything anyone ever wanted to know (and more) about Brushless DC Motor Fundamentals ...John in CR said:With the current alternating direction through the motor phases, that is each phase sees current in each direction that alternates with the firing sequence, I'd call it a type of AC.
https://www.monolithicpower.com/pub/media/document/Brushless_DC_Motor_Fundamentals.pdf ...
So, BLDC is alternating current, but is it the same 3-phase sine wave of say, a traditional 220V AC motor?... The primary difference between AC and DC motors is the power type applied to the armature. From this vantage, a BLDC motor is actually an AC motor ... a brushed DC motor converts DC current in an armature coil to an AC current. ... (see pages 8-9)
