onloop
- Joined
- Jun 24, 2013
- Messages
- 600
So here a quick update on this project
1. Sorry can't offer multiple hole configurations for pulley mounting.... it adds to the complexity therefore increases the cost of making each rim, so at this stage not worth it.
2. I am not happy with the rubber compound of this tyre i sourced, its a bit soft, so will be developing a better tyre, same tread pattern but with higher rubber & carbon ratio to increase elasticity & durability. This makes the production price slightly higher & takes longer but the tyres will last a lot longer & perform a lot better.
3. Actual outer diameter when inflated is about 5.35inchs
4. estimated prices is $229AUD for a complete set (4 precision alloy rims, 4 quality tyres, 4 tubes, 2x 64t Aluminium CNC'd pulleys custom designed to seat into the rim perfectly)
OR $149 for a complete set without the pulleys.
5. The weight is higher than i had hoped but these rims are bloody solid as! This means we can run some high pressure when required! My all-terrain prototype boards only weighs 9kg with everything assembled so its really not that heavy when built.. but will try to minimize weight without compromising the rim strength in the final production run.
6. Will probably try to make this happen within 4-6wks
... ideally if i get 20 pre orders for these wheels that will make this happen real quick....
some more pics
some more pics
